Hello, very recently i experienced my first BSOD. At the time i did not analyze it and re installed the most recent drivers. then today i was leaving something to download, when my system suddenly shut off and restarted. as the monitor was off i could not tell if it was a BSOD, but i got the "your system did not shut down correctly, start in safe mode blah blah" message. i downloaded  blue screen view, and it only shows one dump file, which is from my first (assumed) BSOD. it says it was caused by the driver "dxgkrnl.sys", address "dxg.krnl.sys+5d140" and the crash address "ntoskrnl.exe+75bc0". After researching these codes online, i found that the first two are usually graphics card, and the third code is varied. so i question what is the next step i should take, i have updated all of my drivers and i still had the second shutdown (which i am not sure was a BSOD) so i dont know weather to send back my graphics card, or what step to take next. Another question is if the problem is my video card, who would i send it to for RMA? it is an MSI 7870 but it was bought from overclockers, and some pages suggest that the retailer offers the RMA. and the graphics card i purchased has also been canceled on overclockers, so i am worried that i will not receive any support. thanks for any help!
