I have an MSI 290 Gaming and it looks like it's drooping a little from the weight, is there a tidy way of supporting it at the front to help stop this?
Can you use some cable ties to lift and hold it up?
You should if you can, letting the GPU droop like that is not healthy, eventually it will damage it.
Have your PCI-E cables coming from above it and put some tension in them.
I could do that, but it would look a bit ****.
Will it really damage it?
I'm fairly sure I've had this before, but without a windowed case ignorance was bliss and experienced no problems (that I noticed).
