Graphics Card Help
20 May 2016
I started listing all parts I'll be currently buying for a new Desktop PC (I'm not really a "Gamer")
But I still have no idea on what Graphics Card I should get. I've been Looking at GTX 560s, 660s, 460s, and what not, but I can't decided on which I need
I'm not a huge "gamer". The maximum on high Fps heavy games I would play are likely just CitySkylines. I want to be able to play game like those on 40 Fps minimum at 1920x1080 and low settings atleast
I'm on a budget right now, and I can only really spend a maximum of £70/$100 on this Graphics Card
I already decided to go for an i3 6100 dual core @ 3.7 GHz
I was re directed to this site by the Steam Community as they told me yous could help
Thanks
Edit:
N.B I was also offered a ASUS ENGTX550 Ti NVIDIA GeForce GTX 550 Ti 1GB 192-Bit GDDR5 PCI Express 2.0 x16 Graphic Card for cheap, however I could not find any information about this card
2nd hand you can get a GTX 670 for about £90 or a HD7950 for about £100.
When your budget is that tight it's stupid to buy new.
I had a GTX 770 previouslly. It ran GTA well with a few things turned down a bit. I think you might get one for just over a ton secondhand.
There was a period where the R9 290s were going for sub £100 on MM. But none sells them any more after the DX12 benchmarks :D
Get a msi gtx 770 oc afterburner secondhand can get them on ebay for about £70 they have the stock blower but are slightly overclocked a good card for the price.
That looks like an asus 550ti.
Any reason you want that card or a new card? Both will offer a far inferior experience in GTA V. Heck I doubt he 550ti will run it.
Mainly because I was offered it for cheap, and I'd prepare to have a new one that can hold atleast 4-6 years before I upgrade.
Let's just ignore GTAV for now, since I'll likely get it when I do upgrade to a new GPU, what about CitySkylines?
