graphics card not detected
Sorry about your bad luck mate.
I was wondering what motherboard you had - some have additional power connectors to boost power to the pcie slots. Your previous card may not have required it so you may not have connected it. Additionally, did you try different power leads from your psu, and like someone mentioned they are properly connected at both ends if it's modular (that's a great tip, stored!).
It sucks to have components DOA. The build up in anticipation only to be let down.
I have an Asus P8Z68-V Pro. Only connectors to the MB i can see is the 8 pin and the 24 pin.
And i have tried the alternate two pci-e power leads.
Yeah really does suck!
And means i have to send it back and order a new card which means i will be luck to get a new card by the end of next week =/
