Graphics card power supply question
23 Aug 2010
Sorry about typos, using an iPhone. I'm doing my first build and am confused about the power supply. It's an MSI gtx420 and needs 2 6 pin PCIE and I have one lead that splits into 2 6 pins. Is that the one to use? Thanks!
What is the PSU model?
Most likely the cable that splits into two 6 pin cables (2 rows of 3 pins) is the PCIe power cable, is "PCIE" written on the plugs to confirm this?
showproduct.php?prodid=CA-046-OC stealthxstream2 I was just worried about it needing 2 power supplies and this is one cable that ends in 2 connections. Is that the right one?
You should have 1 x 6 pin & 1 x 6 pin with 2 extra pins loose beside it, this will make the 8 pin for some GPUS.
This is different to the 8 pin for cpu power which is 8 pin (2 x 4 pin)
you should have power connectors similar to these:
as RJC says, the 6+2 pin connector can be used as a 6pin PCI-E power connector, or an 8pin PCI-E power connector, but not as the 8pin CPU power connector.
