Graphic's card problem
6 May 2011
Hi recently my Graphic's card a ASUS HD6590 has been playing up not sure why
When i start my computer up it has problems loading it will often just load until i restart the computer if it does get to the desktop it will freeze and the loading circle on the curser will be there
I tried loading in safe mode and go to the catalyst control center and it said that there is either an out of date driver or a problem with the hardware i have downloaded the latest driver's
If i keep restarting the computer after a while it will load up properly (Usually takes about 30-45 minute's of turning off at the power supply/restarting) after it has booted up properly it is fine
What would cause this?
Thank's in advance for any help
could be a number of things.
swap test the memory and/or run a memtest to check the memory
clear the cmos, could be a bad overclock
power supply could be on its way out
run off onboard graphics if you have it and see if it keeps happening and/or borrow a friends gpu to test
AMD drivers are usually ok, but could be them... download driver sweeper, use it to uninstall all amd software/drivers restart and reinstall latest drivers.
