Graphics card Query
1 May 2023
Wiltshire
I have been looking to upgrade my pc a bit as at the moment i am using the integrated graphic of my proccessor and this is become a slight draw as i would like to not only attempt to use and program compute shaders but it is also quite limiting for the games that i can play so i have been looking into getting a gpu however i would like some advice so that i can get the right graphics card for my pc and my price range of around £400 - £500 however am thinking about maybe up to £600
specs
CPU; intel i5-4460 quad core 3.20GHz
RAM; 16GB DDR3
Graphics; intel HD Graphics 4600
power supply; fujitsu 250w
motherboard; fujitsu D3230-A13 GS 4
any help would be apreciated thank you
specs
RAM; 16GB DDR3
If you get a new power supply, that would greatly help. A good 750 watt PSU would be needed.
Also, you are running a very old system, so modern GPU would be limited by the 4460.
I would instead invest the money in a new CPU, motherboard, RAM, and PSU.
I have no knowledge of that motherboard, but I am unsure if it even have PCI express or capability to run a modern GPU...
The CPU will massively limit any £300+ dGPU.
For £600,you could do a full system upgrade:
My basket at OcUK:
Total: £603.95 (includes delivery: £7.99)​
But if you shop around you might be able to get an RX6650XT into the build,etc.​
Can you elaborate a bit on what exactly you need?
From the power supply and motherboard, it sounds like this is a proprietary PC so I'm not sure you can upgrade the PSU, that's going to limit your options. Something like a low profile GTX 1050 or GTX 1650 might be the best option (if you have a compact case, but I don't know if it is).
Looking at the motherboard it appears to be this system:
My basket at OcUK:
Oh I didn't realise that a full rebuild would have been an option with the limited budget thank you that definitely would be something that I would look into then
Yea from reading some of the other post it seems that a rebuild would be more beneficial so I'm now thinking of taking that route but I belive by mother board had a pcie slot when I had a look but I think a rebuild would be better thank you
Yea I would advise a full rebuild, what you already have is very old and if you were to ask it to power even a basic GPU now it would be highly likely to turn itself into an IED with a PSU that weak.
I think a complete refresh is in order.
Drop to 16 GB RAM and add a case like the Kolink Citadel Mesh. You should also add a SSD.
AMD option:
My basket at OcUK:
Total: £651.92 (includes delivery: £7.99)​
Intel option:
My basket at OcUK:
Total: £711.92 (includes delivery: £7.99)​
Better quality components will increase the cost.
You should check if you need CUDA, because that will mean you are best served by a Nvidia GPU.
£100 (incl. VAT)
£90 (incl. VAT)
£46 (incl. VAT)
£44 (incl. VAT)
