How did I know it would be a 290.
You didn't. And FYI there's been threads with nvidia cards doing the same thing.
The other side seems to be completely fine. I see the regulator but I was expecting more charring/damage to it or its surrounding traces
Sorry was late and probably didn't do a good job of explaining myself.
If you look at the photos , the charred area is in the shape of the regulator below it , there is nothing in that exact area to catch fire and bare pcb doesn't burn with exposure to a drip or two of water. it looks to me that the regulator has just got very very hot very very quickly.
@OP it doesn't have to be a leak. If the difference of the coolant liquid temp is far greater than the environmental temp, it will make condensation on the outside and drip to the card.
Personally I do not believe is issue with the card, but just water from your water cooling above.
Tell me if I'm wrong but I'm pretty sure if you used actually coolant even if it leaked it wouldn't have caused a short as its not conductive?
I've had leaks and fluid on a lot of components and have never drastically tried clean up whilst I'm still building a loop and testing. Obviously afterwards I make sure but I don't think it would have been caused by the coolant making it short.
The conductivity of coolant should be very low due to low ion concentration, still slightly conductive due to presence of dissolved CO2 (very small amount though). Which is why I find it unlikely that a leak would cause such a violent short
If that is the case, then it is very disappointing that the card doesn't have a fail-safe built in for these sorts of components. I am not too familiar with gpu components, but this is a picture of the other side. Is this the regulator that you mentioned?
Yeah thats the one, if you flip it over is the burn in exactly the same place ?
yeah, you can see the bulge from where the heat has expanded the pcb on one side (on solder join of the regulator) and then burnt through on the other side
Nope... just off AMD cards!Bet this has put some people off doing watercooling now.
Nope... just off AMD cards!![]()
And the next time you complain about not getting any work done... guess what!!The next time you come over moaning about how hard you work i'm going to point out the about of forums posting you do![]()
I had a SATA connector to a dvd drive catch fire last year, luckily i was home and using it at the time but i will never leave my pc on and unattended again.
Hmm this doesn't look good!
Just curious, did you have the GPU overclocked or overvolted? What power supply do you have?
