- 15 Jun 2019
SO i decided to try and build a very low Budget PC. I got hold of an old Dell Vostro 460 (i5-2400 3.1GHz, 8GB DDR3, 500GB HDD. I have seen others add Graphics cards to these and use them as very basic/budget gaming PC (Just Fortnite basically) I also bought a MSI radeon RX580 8gb.
So i installed WIN 10 before installing Graphics card. Everything loads fine. PC works. However the issue lies after i installed the graphics card. Nothing will load. The PC turns on. Fans spin on the CPU Cooler and the graphics card.
My initial thoughts were the card is damaged. I checked it in my own PC, works fine. My Next thought was maybe the PSU isnt powerful enough for the Card. i installed my PSU from my own PC and that didnt fix it.
My guesses as to the cause basically end there.... My final thought was maybe the MOBO isnt compatible....?
I would really appreciate any help with this please
