- 30 Sep 2005
Right, it seems a few of you are confused with how to connect your computer to a HD flat screen tele. I'm going to quickly write down some notes and will be updating this post when I get time in the hope it becomes a sticky to help a lot of you out. I'm not expert so if you find anything wrong, rather than flame please help me out
so here goes.....
LCD and Plasma screens have a whole host of inputs on the back ranging from
VGA, DVI, HDMI, Component, SCART, S-Video, Composite
Depending on what graphics card you have you will have these options in order to connect your PC to your HD set
Graphics Card > TV
VGA > VGA (PC Resolutions only) Analogue
DVI > DVI (PC Resolutions only) Digital
DVI > HDMI (Special cable required) (HD Resolutions only) Digital
Component* > Component (Special cable required) (HD Resolutions only) Analogue
Resolutions your TV supports
You will need to research your paticular model in order to find out what resolutions it supports. These are split into two categories (PC and HD)
PC
The PC resolutions will be available on the VGA and DVI ports and will most probably allow 640x480, 800x600, 1024x768, 1024x1028. Please note that these are not HD resolutions but only as a means of connecting your computer to the TV
HD
HD resolutions are available over the component and HDMI ports and are either 1280x720 or 1920x1080
Windows Desktop
1:1 Pixel Mapping
Games
Playing PC games on your HD TV can be quite tricky if you want to run them in an HD resolution on one of the HD input ports. Most people stick to PC resolutions as it's easier but you're not getting the extra quality which HD brings. To play games at HD resolutions you need to tell the game to display in either 1280x720 or 1920x1080 or your TV will go blank if using HD input ports.
Many games have a little VB application you can run in order to tell the game to display in your chosen resolution.
A good example is Need for Speed Most Wanted. This normally doesn't support HD resolutions and will make your TVs screen go blank when you run it. To get around this problem you need to download a small application called "NFSMW Resolution Changer"
Certain games may not have an application which changes the resolution. In these cases you are stuck using the PC input ports and a PC resolution. Unfortunately this won't be a reoslution native to your set so you will see instances of pixel scaling which can make the picture look a little fuzzy. The only way around this is to create a custom resolution using something like powerstrip to match the native resolution of your TV
Blueray&HD-DVD Movies
It's not entirely known if future HD movies will feature encryption but if they do you will require HD Optical Drive, Windows Vista, a HDCP compatible Graphics Card and a HDCP compatible TV. If your TV has a HDMI port you are ok. If you are using a PC TFT you need to make sure it has a HDCP compatible DVI port like the Dell 2407 or an HDMI port like the new 24" BenQ model.
* = Certain ATI Models
so here goes.....
Graphics Card > TV
PC
HD
Windows Desktop
1:1 Pixel Mapping
Games
