Grfx woes!
  • Thread starter Thread starter Fa-
  • Start date Start date
Fa- said:
4743 in 06... first time iv run it...
... but looking around here its not good :S
what the hell is up with my card???
Sounds like only one card is working! Post the comparison link for 3dmark06 and ill have a look!
Thats definately just one card working then im sure. I really dont know what to do now as i dont really no nVidia drivers.
Fa- said:
but it doesnt say sli anywer IN the bios :(
No it doesn't. Its says Multi-GPU-Mode and Single display performance mode. That's it, put them on and is running in SLi. Download nHancer 2.0Beta9, turn on the SLi load balance display with a favourite game and it will show you green bars of both GPU's at work. Looking at your results, your on one core for sure.
Hmm, just ran that nHancer in Prey, and the green sli bar looked the same as the picture you just posted.... :-/
Well if you have the green bars, you have SLi. If I put it in single core mode the green bar goes. So I don't have the foggiest on what could be happening.
Take a moment, give us the specs, speeds and bios settings again. Something is crippling the system. You may need a fresh install tbh.
it is/was a fresh install though :(
all my system settings are in the 3d06 page i posted, i dont know how to get bios settings?
i dont know enough about these things to do this... why the hell wont it work :(
Then i installed the latest drives for all my stuff.
when everything seemed to be working, ran automatic updates... then i think i just put a few games on... that was it basically.
what do you want me to look for in the bios? to write down?
Was it XP SP2?
Do you a have SATA drive, have you installed AHCI (doubt it) if so did you put in the driver disk at install F6? You can't easily do it later (can be done, big pain)
Firstly which Intel drivers (ini's in reality) went in for the motherboard?
Network drivers
Sound driver
Any yellow warning triangles in device hardware?
I'm looking for anything out of place or not installed correctly. Its running with one hand tied, could be a dozen things.
Um, did you flash the bios and you've not been in there, no really?
Check this, look about the same?
Couldnt find anything for my CPU, but i ran the intel test thing and it said its working fine.
i only flashed the Bios when you told me to upgrade, apart from that iv not done anything in there.
im running Xp Prof SP2
heres my hardware
I have SATA, but didnt need to put anything in for them... (i havnt got a floppy drive anyway)
and i installed everything from the P5W disk.
Did you have the previous driver to 91.47?
You could try using driver-clean to get rid of 91.47 and any other nvidia drivers. Then reinstall 91.47 again.
