- 9 Nov 2018
So I was playing a game last night and the game crashed (this is not unusual for this game) and I was unable to kill the thing through task manager so I did a forced power off. When I rebooted this grinding sound started coming from the radiator and it is very loud. Sounds kind of oscillating. I thought it could be the a fan but the sound doesn't appear to come from any of the 3 fans I have on the radiator, only the radiator itself.
Here's a link to a video I made of the sound although it doesn't pick up the grinding noise very well.
I am just dealing with it at the moment as it doesn't seem to have affected performance, but the sound is highly annoying and scary sounding.
The entire set was bought from EK. I'm not 100% sure of the radiator model offhand I can look it up later, the fans are the Vardar fans.
Any suggestions on what this could be or to fix it would be appreciated. It just seemed weird to me it happened right after a forced power off and haven't experienced that kind of correlation before.
https://drive.google.com/open?id=1n5R33bvAzquIajknxeHOAWIGxhtYLniW
Thanks
Thanks
