Has anyone used grip-it fixings? Are they are better than the metal self drill plasterboard fixings?
Ok, bit of background,
Moved into a new build beginning of the year and put up curtain poles above 2 doors with bit of wood attached to plasterboard wall using 4 metal plasterboard fixings. Thought this would be enough to take the weight.
Few weeks ago noticed the fixings were starting to come away from the wall, took everything down.
Would I be better off filling the existing holes in the plasterboard and adding more of the metal fixings to support the weight or would the grip-it fixings in the existing holes take the weight better?
Thanks,
Neil
Thanks,
Neil
