I can't work this one out. The wife's machine has had a Sony 200PS CRT running on an X700 Pro for nearly a year with no problems. Last night I did a clean install of Windows cos the machine was a bit of a mess. Now I can't get the monitor working properly.
It's basically stuck on 60Hz refresh, even tho according to the monitor settings it's on 100Hz. If I switch between 60Hz and 100Hz it looks exactly the same.....infact the monitor doesn't even seem to try and switch. I'm using the Sony 200PS driver that comes with Windows (the one we always used...) and it in display properties it says "Sony 200PS on ATi X700 Pro". So all seems well
To add to the confusion, the ATi Catalyst software doesn't seem to recognise it - it shows as "default VGA monitor" and can't give any info on the monitors capabilities.
I've tried re-installing the monitor drivers, Cat drivers (2 different versions) and even the NET framework stuff. No joy. Any ideas?
