hi guys and girls!
got a problem booting up my pc, not sure where it started as my GF said last night the pc was playing up but i was next door haveing beers so told her to just leave it off and ill look at it later. i came to fire it up and it didnt it gave me a choice of wich boot configuration to use default last setup haveing 1 sucseful boot in the past and a few more saying a range of sucsefull boots. i just pressed F1 to continue the normal prosses as didnt know what that all meant and it restarted and loaded the spash screen for my motherboard (giggabyte Q6), which i had preveusly disabled, so i knew sumething was up straight away. then went to the "verryfiying DMI pool data" page
then grub 1.5 loading
and an Error 17....
i am stuck from here on, i did a bit of searching but everything i found talked about ubuntu or people running dual OS's, which im not just running windows 7 x64 and a few other HDD's for data storage.
so i have removed all HDD but my C:\ but tha same error occurs
can any one shed some light on my problem? i've tried to give as much information as i can sorry if it's long winded.
regards
chris.
and an Error 17....
regards
chris.
