Hi all,
I've recently moved house and have a heating system with a conventional boiler and set of rads (11), a cylinder for hot water, with Hive installed.
I was controlling the Hive system manually until recently as I did not have a hub to replace the previous owners (apparently not transferable). As part of getting the new hub online I had to cycle the power.
At a similar time to the above, I've been having a garage extension and one of the rads at the far end of the house has been disconnected.
I now seem to have an issue where the rads are not fully heating up. I've re balanced them to the best of my ability and bled them, but can't seem to get a situation where all of the rads are a good heat (as they were previous to this work).
Additionally it seems the boiler is cycling regularly (i.e powers on and then goes off).. the pipes coming out of the boiler are hot so assume it's doing its job correctly.
I'm wondering whether as part of the Hive hub swap, the pump setting has changed which is causing the issue?
The pump defaults to constant curve III but from my (limited reading) this is for systems with minimal heat loss and suitable for underfloor heating? Should I switch the pump to proportional pressure or constant pressure for my use case?
Any help would be appreciated as I was supposed to be getting this sorted by the plumber who was doing the garage extension but that work is on hold indefinitely whilst coronavirus is going on!
Cheers
Cheers
