Gsync has to be the most over hyped piece of equipment of the last century. It simply doesn't work.
I had a 60hz monitor, i had GTA stuttering occasionally when using Vsync, frames dipped now and again from 60 to 55-56.. but it was certainly playable.
Got a Gsync monitor in hope it'd fix the occasional stuttering problem, but its made it worse....... can't even hold 55FPS nevermind 60FPS
What next?
EDIT: I've clicked "Set up G-Sync" in Nvidia Control Panel and its set to enabled, however as far as i've read on google i should be seeing a "Gsync" option under Vsync in game settings on the Nvidia Control Panel, i don't see that. Anyone know why?
What next?
