1. Can you disable the G-Sync in the monitor and have it run as a regular monitor if you are playing a game that dips below the 30fps minimum refresh rate so it doesn't flicker or fail or what ever it does?
2. If my GPU can't push the game above 60 fps will I notice any tearing or stuttering?
I have a GTX1070 but I want to be able to play games without stuttering when the frames fall below the monitors refresh rate like they do on my 60hz monitor.
