I'll be using a 24" screenWhat rez u gaming at?
On the motherboard - it depends... I haven't built the rig yet, so if I choose SLI, I'll get an SLI board, if not, I'll stick to standard.does your MB support sli?
if the game you play can ultalise sli, then the 2GTs will be faster, but if it cant then i think the GTX may win.
also what res are we talking about?
.Yeah I knowThe GT's in SLI look pretty promising from benchmarks whilst looking at the X2 3870 reviews but with so many dodgy review sites and the way they do reviews it's not easy to see if it's the real deal.
I don't know if the 256bit memory interface will be a bad thing at the highest resolutions and with AA/AF. At lower resolutions then the GT's would whoop the GTX.
Some compare them with some cards, and others compare them with others
Theres never one review the same
jak731 said:ah, i thought you were jsut upgrading the PC in your sig.
if thats the case, i would say go for a GTX if you want to OC your CPU as intel chipsets seem to be better for that.
I'll also be using the E8400 and overclocking it further.either one GT /GTS/ GTX, then sell up when high-end 9 series come out![]()
When is the 9 series available?either one GT /GTS/ GTX, then sell up when high-end 9 series come out![]()
3870x2 tbh
I would go for 2x cheaper non-overclocked 8800GTs and Sli them.
