GTA 4 INSTALLATION HELP!!!
10 Nov 2007
Southampton
i get half way through installing this game however when it says to swap discs so it can access data3.cab it just idles and says it can't find it :(
when i scan open the disc however i can see data3.cab sitting there...
has anyone else had this problem if so how did you fix it?
Problem solved...went a weird way of doing it though
ripped the image of disc2 using imgburn then loaded it into a virtual drive. once prompted for disc 2 during installation i changed the drive letter in the address bar to the letter of the virtual drive and it installed 1st time no haslle
