See it's weird, I have SLI and a both enabled and disabled I'm getting some stutter. Neither of my Titan X's are getting a huge work out (50% on each card in SLI). I have no idea what it could be.
mouse from raw to direct should do the trick
Getting great performance at 2560x1440, SLI, G-Sync, 144hz, no stutter, looks amazing.
On one hand its great, and im glad it works perfectly with awesome performance. But on the other hand its kinda bad we all get excited and praise them for something that should be standard across all gaming companies.
Is that 980 SLI fella, like in your sig?
Assuming this game isn't locked to 60fps (is it???) could you tell me what sort of framerates you're getting. 780ti SLI should be fairly similar.
Also, what Vram usage are you seeing, if you know?
