GTS SA Performance problems
Caporegime
3 Jan 2006
Chadderton, Oldham
Got some unusual problems in GTA SA.
First of all, everything is at max of course, but outside my fps is around 50-70fps, seems far too low for this card, and then when I get in a car, I am driving along and my frame rate goes down to 25-35 and there is extreme stuttering.
anyone got any idea what is going on?
When i was playing gta:sa if i forced v-sync on in the drivers the performance seemed to take a really big hit. Also have you got the frame limiter switched on or off in the game settings? Still seems very low for that card though.
Patch, defragment, 'let application decide' AA and AF in CCC (do the AA/AF in GTA:SA itself) maybe? Had problems with performance in NFS:MW, turned out it didn't like CCC doing the AA/AF :(
As mentioned above, do you have the in game frame rate limiter switched off?
EDIT: Lmao at your sig knowledge. Da' truf'. :cool:
Frame limiter caps it at 25, as you cans ee in my first post I stated it would go down to 25-35. In parts my fps is around 50-70, in carls house I get 128fps.
naffa said:
Is that a no then?
Well I would have thought so, since I am getting 70 in places it obviously means no frame limiter, when it's turned on the fps is capped at 25fps.
naffa said:
Yeah, I know it's capped at 25. No need to give me a sarcy response for trying to help. :rolleyes:
I aint been sarcy, I thought it would have been obvious the frame limiter was not on since I did state I was getting 70fps in one point.
dunno why your moaning about getting 30 fps ?
its smooth with the limiter on imo
your just noitcing the stuttering because of the ocnstant up and down change in fps
if you ran it maxed on the limiter constantly it would be fine
It is best to play it with the limiter on. With it turned off I experienced some stuttering and also the game would go out of sync - during cutscenes especially. Also I dunno how it affects performance, but I heard the game doesnt get on with multi-core cpu's.
Hmm that may be a good point, I've never tried it untill today on my dual core setup.
I aint using that damnd frame limiter, a game that old and running at 25fps, no thanks, too choppy for me.
The frame limiter did stop the stuttering, but 25fps on GTA SA is awfull for me.
I laways had the limiter on, without it I would get stuttering .
I think that you would get stuttering no matter how fast the videocard is, there is something in the game that is limiting fast framerates sometimes.
With my 8800GTS, X800XTPE, 9600np I did not get stuttering...
Dutch Guy said:
So you had a constant high framerate, or did you have the limiter on?
I did not have the limiter on, and no I did not have a constant high frame rate.
It must be the dual core CPU's.
No its not, especially when driving in MTA the frame limiter ****** me off as when you looked sideways you could see it being all stuttery, while when gone to sa-mp, it was smooth as silk.
25 fps perhaps is smooth for games like rts etc, but for fast driving games, it definatly isn't, while walking it was unnoticable though, but when driving : need about 35 min. to get it smooth.
Hmm willhub, have you disabled everything in nvidia/ccc panels, ie. set it to let app decide?
Also what ingame AA lvl are you on? Lvl 3 was buggy as hell for me it disappeared textures, killed framerates, etcetc, try aa lvl 2.
