Right, I have gone with TechPowerUps 1080P results, as they test the most games and a very informative way of testing.
Gaming results 1080P
Power Consumption
Performance per watt/Performance per Dollar
Overclocking
For more info about the GTX 1060 and other bench resolution results, click here.
https://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1060/
For more information about the RX 480 and other bench resolution results, click here.
https://www.techpowerup.com/reviews/AMD/RX_480/
Great work from TechPowerUp and some decent results. I used the 1080P results, as I would use either of these cards for 1080P gaming and that is where both of these cards perform well.
Power Consumption
Overclocking
GTX 1060
Maximum overclock of our sample is 2380 MHz on the memory (19% overclock) and +229 MHz to the GPU's base clock, which increases maximum Boost from 1911 MHz to 2101 MHz (10% overclock).
RX 480
Maximum overclock of our sample is 2250 MHz on the memory (13% overclock) and 1335 MHz on the GPU (5% overclock).
While memory overclocks really well, reaching the Overdrive adjustment limit, GPU overclock is extremely limited and one of the smallest I've seen in my reviews so far. AMD does offer the option of voltage control, but its effect seems extremely limited, with no noteworthy frequency gains in my testing.
RX 480
