Hi all
I’m trying to install a GTX 1070 but running up against problems when installing the driver. Every time I try an install it gets nearly to the end then tells me the display driver has failed to start and it reverts to the windows basic driver. Device manager then shows a code 43 error for the card. The card is recognised by GPUz although it won’t read clocks and voltages without the driver.
Things I’ve tried:
DDU in safe mode twice
Reseating the card twice
Two different pcie power cables
Disabling onboard graphics in bios
Updating bios to latest version
Installing an older driver
The card was bought from a trusted member on here and I suspect the problem is at my end rather than with the card. I’ve been offered a return and refund if I can’t make it work which is very generous but I’d much rather keep the card and make it work.
Rig spec:
Gigabyte H310m
i7 8700
EVGA 550W
Windows 10 home
Any help greatly appreciated!
Things I’ve tried:
Rig spec:
Gigabyte H310m
i7 8700
EVGA 550W
Windows 10 home
