For people with Gainward GTX260 216 Golden Sample cards with part numbers EAN 4260xxxxx0025 only
This fixed bios solves issues with 2D clocks and voltages running at 3D settings. It should save you electricity and extend the life of your card.
You need these files.
0025 BIOS
NVFlash
Instructions.
1). Read the sticker on your card to confirm part number. It must begin 4260 and end 0025.
2). Make a DOS bootable floppy or USB disc (use Google if you do not know how).
3). Copy above bios and unziped NVFlash onto disk.
4). Change PC bios (if necessary) to boot from floppy.
5). Boot from Floppy
6). Backup original bios with command "NVFLASH -B BACKUP.ROM"
7). Flash new bios with command "NVFLASH -5 -6 0025260.ROM"
8). Hit "y" key when prompted and hold your breath.
9). Restart your PC and check 2D clocks work correctly.
If you brick your card it is your fault for following instructions an unknown person posted on the web. However, this is the official FIXED Gainward bios which I sourced directly from the Gainward Tech Support chaps in Germany. It worked for me.
This will not work on any other card because Gainward (it's actually made by Palit for Gainward) use non-reference parts.
This info is not available anywhere else (yet), so all credit goes to me
