- 12 Jan 2009
Hello people
Basically I am getting problems with my PC crashing while playing Call of Duty Black Ops, and running GPU stability tests.
Symptoms
Black Ops:
1. Game freezes, with sound looping... Sometimes I can CTRL + ALT + DEL to bring up Task Manager, and the game comes back...
2. Screen goes black. The system does not seem to have frozen (clock on G15 still counting), until I try to CTRL + ALT + DEL, which completely freezes system.
3. In Black Ops Menu (not 3D), Screen goes black (loses source signal), then comes back to desktop - screen comes on as if source is back on...
FurMark
Running Multi-GPU version, the test runs for about 4-5 mins, with temps getting to 98C, then the test freezes, but G15 clock still runs - CTRL + ALT + DEL freezes system...
Errors
I have once noticed an error "bubble" in the System Tray, saying "Display Driver Nvidia Windows Kernel Mode Driver Version 266.58 stopped responding and has successfully recovered"
3D Mark Vantage runs fine.
Temperature and Voltage Reports - Playing Black Ops until the game froze at 632 seconds >>>> CPU and GPU Graphs
Basically, I am trying to figure out whether it is a Hardware or a Software problem. I have tried a full system re-install and driver sweepers.
My Rig
Operating System: Windows 7 Pro x64
Motherboard: EVGA 132-CK-NF78 (Socket 775)
BIOS: P10 (30/12/2009)
CPU: Intel Core 2 Quad Q9450 @ 2.66GHz, Yorkfield 45nm Technology (O/C @ 3.20)
Cores 0, 1, 2, 3 @ 3599.7 MHz, Multiplier x8, Bus Speed 450 MHz, Rated Bus Speed 1800 MHz
RAM: GSkill 8.0GB Dual-Channel DDR2 @ 539MHz (5-5-5-15)
Graphics: BFG GTX 295
Video Forceware (Drivers): 266.58
Audio: SB Audigy Platinum
PSU: Cooler Master Silent Pro M850
I hope someone can help or suggest anything :/
Symptoms
Black Ops:
FurMark
Errors
My Rig
