- 21 Oct 2004
- Wales
I am sending back this card for an RMA but in the meantime I was wondering if I could rack your brains on what be happnening to it. Basically it runs like its not getting full power. After testing the connection of the 6-Pin connectors I ran some tests and the performance was way lower, like half of what the card was capable of. Then I tried reseating the connectors and the performance did go up but it was by a small margin. When under half load it makes a noise sounding like its straining.
It seems like the card is only getting 3/4 of the power from the 6-Pin connectors on the side of the card. I have put in an RMA explaining there could be a problem with the power going to the card and hopefully they will find the same problem and get me a replacement sent out.
If not, then the problem lays elsewhere in my system which is actually a blessing and a curse, blessing because my beloved card works properly, curse cause it means the last thing it could be the PSU but I have tested the graphics card with a 600W PSU by itself and it still exhibits the same behavior.
