GTX 680 2GB SLI problem
4 May 2015
Hi everyone,
I have a problem with my GTX 680 2GB SLI
When I Play BF4 on SLI it is crushing every 5-10 min. When I switch of SLI everything runs fine please check the link bellowfor more details.
a8adbf68
My spec:
Intel i7 2700k
ram 16GB
GTX 680 2GB SLI
Gigabyte z68XP-UD4 v1
Asus rog swift 27 1440p
Windows 10 64bit home
THANK YOU FOR YOUR HELP
My guess is one of the cards is overheating. Are they overclocked? If so dial them back down to stock and try.
What type of coolers are on the cards? If they aren't blowers you might want to look at increasing your case airflow.
Also the main card is the one under more stress, you could try swapping them over, if one of them is weaker than the other.
Another possibility is that the settings you are using @ 1440p are too high for only 2GB VRAM and that the crashes are coming when you breach the VRAM limit of the cards.
Edit: Looking at link, I think it probably is a VRAM issue with the way win10 handles VRAM, Try dialling back your settings.
its maxing vram according to that error. turn AA down and tray again.
On the sli one its just adding the 2 cards vram together some games do that.
Thank you for a quick replay :-)
Both cards age water-cooled, they are not overclocked.
how can I limit the memory usage to 2gb on both cards?
single card runs perfect on the same settings please see the picture :-(
You also have a massive increase in system RAM Usage in SLI that's why I asked about page file,
Being quite an old game now and having run it fine on SLI 680's in the past on windows 7, I'm concerned for you this might be the game with windows 10 issue
