gtx 690 watercooled problems
11 Mar 2012
portsmouth
hi guys i really need some help, just completed my 1st watercool build 360 top 2x240 bottom 1x120 rear no leaks all running perfect.
my gtx 690 watercooled using ek block and backplate is the problem nvidea panel is not recognising it and in control panel i dont get my 2560 1440 moniter resolution not even sure if its working i am plugged into hdmi port which is giving me desktop display. reinstalled latest drivers, cant get asus gpu tweak to install.
have i messed up waterblock install i done everything as to the ek tutorial.
please reply guys as i got no idea what to do now.
thanks.
ok will give that a go, does this mean my 690 is working as display as i am not plugged into to motherboard hdmi port.
ty
yes bunnox i am plugged into 690 hdmi port so does this mean that the 690 is functional as i have desktop display.
ok guys thanks for advice will try older driver clean install if this fails ill get some new thermal pads and redo waterblock.
thanks
thanks for all the help bunnox older driver worked all fully functional idle gtx 690 21c now for some stress tests and overclocking.
thanks a lot.
