GTX 780 and BF4 issues
25 Jan 2009
Leeds
Hi,
I have a KFA2 GTX 780 ( This one )
The issue im having is that every time ive started my pc up and want to play BF4, it ALWAYS goes into windowed mode and cant get it to go full screen. Everytime i click the game it goes full screen then back to windowed straight away, i've also tried Alt + F4 with no joy.
The only way to fix it is to remove the drivers, reinstall them and then restart my pc. Then if i turn my pc off and go back to it the next day it goes back to windowed mode again so i have to repeat the steps above.
Has anyone had any experiance of this? or perhaps have a fix?
Once was weird, twice was annoying and now its really irritating and actually stops me playing.
Any help would be great, Thank you!
If you click into the window you can use the keyboard shortcut Alt+Enter to force it to become fullscreened.
If not, delete your specific BF4 user.cfg file (search web for location) and start again with fresh settings.
Tried the Alt + F4 with no luck, will try the config part though thank you!
Disable Samsung Magician if its running. (Don't need to uninstall it just make sure its not running).
I do have that running so i will try it without that running. Is this something you have tried?
Regards
Known issue with Magician and the way it works that can on some configurations cause issues with DirectX that can prevent applications having access too exclusive fullscreen modes. (Noticed you have a Samsung SSD in the sig).
