GTX 980 Ti GV-N98TWF3OC-6GD reference PCB / waterblock?
26 Aug 2004
Haven't seen too many reviews on this particular Gigabyte GTX 980 Ti GV-N98TWF3OC-6GD
Does anyone know if it has the reference PCB and which water blocks would be compatible?
Kind regards
If you want reference then buy one with a reference cooler and that way a water block will fit.
Probably cheaper too considering your taking off the reason to buy that Windforce card.
Kind regards
Hi l bought the 980 Ti poseidon £620 OcUK its air cooleed or you just add it to your loop you just need to fittings.
Upgraded from SLi 4GB 670 well worth it as l game at 1440p, using the DSR sitting really nice graphics.
I think he's already bought the windforce card, going by his wanted thread.
I don't think it does have a Reference PCB. I remember reading something about EK not releasing a block yet? Or it may have been something else!
The g1 and windforce are basically the same card but the windforce has less coil whine.
I have a pic somewhere of my windforce before i fitted a thermosphere block and the layout is identical with just a few components with different numbers
That is a pic of my windforce with the cooler removed, if you compare it to the pic of the g1 on ek's configurator you will see its basically an identical layout with some components the same shape but different numbers
I put the g1 firmware on my windforce and it screamed during heaven benchmark so i put my modified windforce bios back on and its so much quieter.
Boosts to 1500 on stock volts no probs
Thanks for the picture, very helpful indeed.
no probs m8
its a shame at stock they are limited to the 104% power limit but with a bit of reading and faff i got it upto 119%
I had the bios modified within a day of buying the card m8 and didnt really do much testing before so i couldnt say but i doubt it would be 100% game stable
Dont know about the led's or even if there are any tbh as i fitted the water block the day it was delivered, it was only plugged in on air to test it wasnt doa
Ok ta!
Did yours come with a backplate?
