Gtx vs Gts640
28 Mar 2007
I love the Evga KO editions of these cards but is the exspense of the gtx worth it over Gts. Plan to upgrade to a tft sammy 22" or Sammy/Del 24".
Will be run on a commando mobo with duo6400 and 2g rv2 platinum Ocz.
If you go for the 22 inch a GTS is plenty. However, for the 24 inch you may want to consider the GTX. Having said that, my GTS is running everything i throw at it on my 2407WFP no problem. Don't know if this will still be the case come crysis though.
wellibob said:
I would consider a GTS 640 , and if you get one that clocks like my Leadtek , 690 - 2140 , its has some power indeed ;)
Is yours 690 on Air? :o, I only manage 650/2.2ghz on mine :(
If you're considering gettin a new monitor i'd also look at the new 24" Sammy coming. It looks the nuts and i'm sure it'll follow Samsungs normal build quality.
Also, i went from a GTS 640 to a GTX and must say that i've noticed a difference in MIN frames/sec. I'd recommend the GTX if you can get one at a decent price, i got mine for £309 all in which meant when i sold my GTS for £240 the upgrade was only £69, bargain IMO.
Depends. Do you want to pay £100 pounds more on a better performing card (usually about 25% from most benchmarks).
nice clocks wellibob most i can get my 8800gts is 620/980 anything higher and it just freezes,mine is the bfg version
