Even with your fans set to max, those temps are pretty insane man. It’s not just your core temps, the VRM temp/s will cause throttling too.
Added heat will cause higher power consumption which means you’ll hit the power target quicker and not achieve the same boost clocks as before. Looks like you’re already hitting the 100% power limit.
