Right, different GTX295, different system. Getting this strange problem after completing a WU. Then it just loops from "Attempting to send results" until it does too many Unstable Machine errors to continue. Happens on both cores, driver issue maybe?:
[03:26:35] Completed 98%
[03:27:25] Completed 99%
[03:28:14] Completed 100%
[03:28:14] Successful run
[03:28:14] DynamicWrapper: Finished Work Unit: sleep=10000
[03:28:25] Reserved 84576 bytes for xtc file; Cosm status=0
[03:28:25] Allocated 84576 bytes for xtc file
[03:28:25] - Reading up to 84576 from "work/wudata_01.xtc": Read 84576
[03:28:25] Read 84576 bytes from xtc file; available packet space=786345888
[03:28:25] xtc file hash check passed.
[03:28:25] Reserved 25248 25248 786345888 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[03:28:25] Allocated 25248 bytes for arc file
[03:28:25] - Reading up to 25248 from "work/wudata_01.trr": Read 25248
[03:28:25] Read 25248 bytes from arc file; available packet space=786320640
[03:28:25] trr file hash check passed.
[03:28:25] Allocated 560 bytes for edr file
[03:28:25] Read bedfile
[03:28:25] edr file hash check passed.
[03:28:25] Allocated 0 bytes for logfile
[03:28:25] Could not open/read logfile=<work/wudata_01.log>; Cosm status=-1
[03:28:25] GuardedRun: success in DynamicWrapper
[03:28:25] GuardedRun: done
[03:28:25] Run: GuardedRun completed.
[03:28:27] + Opened results file
[03:28:27] - Writing 110896 bytes of core data to disk...
[03:28:27] Done: 110384 -> 109756 (compressed to 99.4 percent)
[03:28:27] ... Done.
[03:28:27] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[03:28:27] Shutting down core
[03:28:27]
[03:28:27] Folding@home Core Shutdown: FINISHED_UNIT
[03:28:31] CoreStatus = 64 (100)
[03:28:31] Unit 1 finished with 99 percent of time to deadline remaining.
[03:28:31] Updated performance fraction: 0.993553
[03:28:31] Sending work to server
[03:28:31] Project: 6601 (Run 9, Clone 693, Gen 205)
[03:28:31] + Attempting to send results [July 25 03:28:31 UTC]
[03:28:31] - Reading file work/wuresults_01.dat from core
[03:28:31] (Read 110268 bytes from disk)
[03:28:31] Connecting to
http://171.64.65.61:8080/
[03:28:36] Posted data.
[03:28:36] Initial: 0000; - Uploaded at ~21 kB/s
[03:28:36] - Averaged speed for that direction ~21 kB/s
[03:28:36] + Results successfully sent
[03:28:36] Thank you for your contribution to Folding@Home.
[03:28:36] + Starting local stats count at 1
[03:28:40] Trying to send all finished work units
[03:28:40] + No unsent completed units remaining.
[03:28:40] - Preparing to get new work unit...
[03:28:40] + Attempting to get work packet
[03:28:40] - Will indicate memory of 6135 MB
[03:28:40] - Connecting to assignment server
[03:28:40] Connecting to
http://assign-GPU.stanford.edu:8080/
[03:28:42] Posted data.
[03:28:42] Initial: 40AB; - Successful: assigned to (171.64.65.61).
[03:28:42] + News From Folding@Home: Welcome to Folding@Home
[03:28:42] Loaded queue successfully.
[03:28:42] Connecting to
[03:28:43] Posted data.
[03:28:43] Initial: 0000; - Receiving payload (expected size: 74336)
[03:28:44] - Downloaded at ~72 kB/s
[03:28:44] - Averaged speed for that direction ~72 kB/s
[03:28:44] + Received work.
[03:28:44] Trying to send all finished work units
[03:28:44] + No unsent completed units remaining.
[03:28:44] + Closed connections
[03:28:44]
[03:28:44] + Processing work unit
[03:28:44] Core required: FahCore_11.exe
[03:28:44] Core found.
[03:28:44] Working on queue slot 02 [July 25 03:28:44 UTC]
[03:28:44] + Working ...
[03:28:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 3432 -version 623'
[03:28:44]
[03:28:44] *------------------------------*
[03:28:44] Folding@Home GPU Core
[03:28:44] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[03:28:44]
[03:28:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:28:44] Build host: amoeba
[03:28:44] Board Type: Nvidia
[03:28:44] Core :
[03:28:44] Preparing to commence simulation
[03:28:44] - Looking at optimizations...
[03:28:44] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[03:28:44] - Created dyn
[03:28:44] - Files status OK
[03:28:44] - Expanded 73824 -> 383588 (decompressed 519.5 percent)
[03:28:44] Called DecompressByteArray: compressed_data_size=73824 data_size=383588, decompressed_data_size=383588 diff=0
[03:28:44] - Digital signature verified
[03:28:44]
[03:28:44] Project: 6600 (Run 10, Clone 922, Gen 6)
[03:28:44]
[03:28:44] Assembly optimizations on if available.
[03:28:44] Entering M.D.
[03:28:51] Tpr hash work/wudata_02.tpr: 1542977918 4078650811 266603496 1470683992 346959629
[03:28:51]
[03:28:51] Calling fah_main args: 14 usage=100
[03:28:51]
[03:28:51] mdrun_gpu returned
[03:28:51] Going to send back what have done -- stepsTotalG=0
[03:28:51] Work fraction=0.0000 steps=0.
[03:28:55] logfile size=0 infoLength=0 edr=0 trr=25
[03:28:55] + Opened results file
[03:28:55] - Writing 637 bytes of core data to disk...
[03:28:55] Done: 125 -> 124 (compressed to 99.2 percent)
[03:28:55] ... Done.
[03:28:55] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[03:28:55]
[03:28:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[03:28:59] CoreStatus = 7A (122)
[03:28:59] Sending work to server
[03:28:59] Project: 6600 (Run 10, Clone 922, Gen 6)
[03:29:31] + Attempting to send results [July 25 03:29:31 UTC]
