GTX480 SOC off for RMA - what to replace it with ?
20 Aug 2006
any help appreciated please.
my 480 SOC (Gigabyte) is going off for repair this week- its never run at stock clocks properly (the Gigabyte high OC clocks that is)- but this week one of the fans has become very noisey -no idea why - sounds like it is almost catching on something. I de-dusted, checked for any of the blades catching on metal-work etc to no avail - so must be the bearings going on it. So off for RMA.
since this will prob take a few weeks - and I've already had enough of the HD4000 integrated lol - prob a good time to upgrade
considering the slight price difference between a oc'd version of a 670 and a 680 (50-60 quid) - is it worth getting the 680 ?For instance Gigabyte 670s (Windforce varients) go for around £300 - yet you can get a EVGA SC Signature 680 for £350 odd- but I'm guessing that even though only 50 more - prob not worth it ?
or should I just get a cheap 7950 (Gigabyte one for instance) and oc it to the max ?
only thing that puts me off the ATIs - is whether they are still as driver dependant as in the past ? My 4890 used to be fantastic in some games - and some non-optimised (including some older games) - it was not as good as my previous 8800GTX ! Including some flight sims like FSX.
I game at 1900 - although next monitor I'd like to be 2560x, and I like lots of AA applied (4 or 8x) - especially when playing flight sims.
btw - can I assume some of the older bugs with ATIs have been fixed ? for instance with my 4890 - I couldn't have a youtube video or itunes video playing in background (to listen to) whilst playing a game -as it would prevent the GPU going to full core clock speeds -it would be stuck in "media"/desktop clocks.
btw - I could wait for the 480 to come back - but I'm quite impatient. I suppose I could grab the 4890 out of the old PC.
thing is - with nothing really coming out GPU wise for PCs this year - I probably may as well upgrade sooner than later
thanks - the 7950 does sound tempting
but you are right perhaps I should wait - last time I think it did take a while I'm pretty sure it was at least 2 weeks if not longer
its with slight trepedation sending it back tbh - as Gigabyte support didn't fill me with confidence last time - I sent the 480 back as wouldn't work at stock clocks of 820 core - I get artifacts in all games, furmark etc - yet when Isent it back - they returned it as no fault found, stating they had run heaven, furmark etc all at 820 at stock core volts, with no issues! :( yet on my system best I can manage is 740 at stock core volts ! And when I say a few artefacts - I mean serious numbers - for instance run furmark and you immediately get flashes all over the screen, heaven you get missing textures, triangles all sorts etc.
I had thought it was either my mobo (old P5B Deluxe) or my old PSU - Tagan one, but since then I have upgraded to a 3770k + Gene V and a Corsair HX850 - and made not one jot of difference.
:( and they reckoned 5 hours of furmark without a glitch !
only difference was they were running on a bench - perhaps lower temps ?after 5 hours of Furmark they managed 70C !
I had option to send it back to them - but intheir report they sent me photos of the card on test (mine), and 12 screenshots of it under test etc -and I was told I would be charged if I sent it back and they re-found no fault.
very annoying- and had sort of put me off their brand. but I thought - I can't push too hard - as might be my psu
I now know the PSU and mobo were not at issue - it must be the card.
well 480SOC RMA application made today :)
re replacemet GPUs - I hear what people are saying re 7950s/7970s - but if I was to be firm in Nvidia camp - and want to stick to around £350
would you go Gigabyte 670 4gb - or something like an EVGA SC Sig 680 for same price ?
whilst I don't have a >24 inch monitor now - might I before I upgrade the GPU again ? possibly ? will games start using >2gb soon even at 1900 ? possible - so I'm half thinking as the 4gb Gigabyte should clock near to the 680 - its a better bet - even though really 350 for a 670 is a bit pricey
^^ prob - my 480 with the 2 fans fixed
and they'll ignore the artefacts (again !)
if it does come back with them stating it works at stock clocks with no issues I'll be at a complete puzzle/loss - as I can't imagine that there can be anything wrong at my end ?
serious artefacts in Heaven, games, and immediate strobing, flashing etc in Furmark - check
change PSU - check (HX850)
new build this year - with the HX850 and a new 3770k + Gene V - still artefacts - check
new OS - Windows 8 - check
so how can it possibly be me ? yet checks out AOK at Gigabytes end ? they reckon they tried Furmark (5 hours), Heaven, 5 games - with not one artefact
only difference they are using a Gigabyte mobo - I'm using an Asus one
only other difference they are testing on a bench - ie GPU is cool - and mine is in a case - so prob 20C warmer
only thing I can think is that
(1) Gigabyte boards apply slightly more power to PCI-E socket (doubtful)
(2) temp is the factor - ie the higher the temp - the more current the GPU IC draws (quite possible)
very frustrating
for reference - if I keep volts same (1.038V) in Afterburner, and reduce clock from 820 to 740 - card is perfect, not one artefact
thanks for asking
got my RMA code today (within 12 hours) - and sent today - via RM SD - so will be with them tomorrow
wrote a page of A4 describing the artefacts and how I had tested on multiple machines, different PSUs etc to no avail - so lets see what happens
if it comes back no fault found - I may be asking for some help on here to see if I can completely independently check it out :) (please)
yeah wishful thinking :)
I genuinely upgraded from a 570 to a 480 - for the extra memory, extra memory bandwidth etc - as a 480 SOC is no slouch at its OC'd speeds
I like games at 1900 with lots of AA (8x normally) - and the 480 feels more consistent to me than my previous 570
all be it hotter and more power hungry...
