Case airflow is made up of a front 120mm fan, rear 120mm fan, a bottom slot PSU and the Xigmatek Gaia CPU cooler. Case is the Coolermaster 311+.
CPU temps are between 35C and 45 dependant on core, so I can't understand why my GPU temps are so high given ambient temps are around 10-15C with no central heating.
GPU is running stock and fan at stock 40%.
Guru3D got 31C idle, but I'm not sure what case cooling they use. I was at least expecting sub 40C idle.
Would I simply need a fan pushing air from the front of the case and through the GPU?
