Guess my temps....
1 Dec 2011
Ok so old loop:
2 x 7950
D5
1 x thin 360, slow fans
Max temps after long heaven 4 run with cards at 1200/1600 56 degrees.
New loop - same as above but with extra 200mm rad with 700RMP fan intaking.
Guess my new temps folks - same as before, heaven 4 with cards at 1200/1600, long run until temps stabilise.
The prize is honour only I am afraid.
Panyan - don't forget overlocked cards run at about 12c over water temp. To get 30 the water would have to be at ambient in a cool room.
AND THE WINNER IS pgi947 !!
45 on one card 46 on the only (cards in parallel).
One card hit 47 for a couple of seconds during a half hour period of stability so I'm discounting that.
The room is probably a bit hotter tonight that it was yesterday when I bit the last test so I think that is a solid 10c deduction.
Pretty happy with that.
I was a bit worried that having the new rad on intake would mean only a minimal improvement but luckily I was wrong!
