Man of Honour
- 11 Dec 2002
- Darkest Norfolk
Chris1712 said:Beat you by one minute![]()
bah, could have been seconds!
Is it the 800bhp jobby from the pikes peak celica? 2.0 inline 4 turbo'd, dunno the engine code though.
Siliconslave said:oooh, is it that 2.1l TRD Straight 4 turbo engine putting out about 800bhp
developing over 1000HP in qualifying tune, 800HP for sprint races, and 600 for endurance events
Zip said:Nope![]()
Chris1712 said:Its from the Toyota Eagle MKIII.
Hate said:thats not even an engineand that car uses the 3S-GTE anyway
JRS said:And it can't be a 3S-GTM, unless I'm seeing a different engine.
***edit***
Maybe it can.
http://www.allamericanracers.com/images/eagle_mk3_d600x300.jpg[IMG]
I'd just like to say, thats insane power from a 2.1![/QUOTE]
wouldent say insane, wern't 80's F1 cars in qulaifying form pusing well over 1000bhp from a 1.5litre engine?
Zip said:Who wants the Engine code given to them?![]()
Chris1712 said:Toyota 3S-GTM L4 4v 2140cc Twin-Turbo
JRS said:Already ruled out.
. Twice!Chris1712 said:The interweb tells me otherwise though, i even the picture of the engine, the very same one with text next to it. Twice!
The most famous and successful Toyota Race engine- the 503E was used in Toyota's Triumphant Championship seasons in IMSA GTO / GTP, Pikes Peak, Le Mans, and in the mid-90s Japan Touring Cup Championship. It is important to note that the 16 valve cylinder head layout from the 152E engine and the T block crankshaft saddle design were used as design base for this ultimate Toyota 4 cylinder Turbocharged race engine. The 503E represented the most powerful 4 cylinders in competition history developing over 1000HP in qualifying tune, 800HP for sprint races, and 600 for endurance events. IMPRESSIVE.
Zip said:I dunno![]()
They are very similar but nothing alike from what ive read.
Its a Toyota 503E
I know that toyota (and other teams) state that the 2 liter motor is a 3S-GTM but it's really not. It's a 503E. This has been argued about numerous times on the MR2 owners board and it was finally proven by a board member who posted a website about it. The two motors are similar, both are 2 liter, both are turboed, both are 4 cylinder, but that's it. The block, pistons, crank, etc. are completely different in both motors. You can buy a 503E from toyota for around $15k-$20k.
Toyota 3S-GTM 4-in-line, water-cooled, blown. 89.0mm x 86.0mm / 2,140cc. Single Toyota twin-entry CT44-ST turbocharger. Linerless iron block, aluminum head. 5 plain main bearings. Steel crankshaft. Steel con rods. ART light alloy 3-ring pistons. Toyota rings. DOHC, belt driven. 4 valves/cylinder (36.1m inlet – 31.5mm exhaust), 1 plug. Nippon Denso ignition, injection and engine management system. Compression ratio 7.0:1. Borg & Beck triple-plate clutch. Unstressed chassis member. 680 bhp at 8,500 rpm. Weight 140 kilograms.
Sone said:wouldent say insane, wern't 80's F1 cars in qulaifying form pusing well over 1000bhp from a 1.5litre engine?
