Looking for some advice.
I recently built my first AMD system in over two decades. The specification can be found below:
MSI MAG X570 Tomahawk WiFi
AMD Ryzen 9 3950X
Noctua NH-D15
64GB Patriot Viper Steel DDR4-3600
1TB Samsung 980 Pro M.2 PCI-e 4.0 NVMe SSD
PNY GeForce RTX 2080 Ti 11GB XLR8 Gaming Overclocked Edition
EVGA SuperNova P2 1000W ‘80 Plus Platinum’ PSU
I am running the latest (non-beta) BIOS, Windows 10 20H2, with all drivers up to date.
There are two areas I am struggling with.
1. I was under the impression the Ryzen 3950X had a default vcore of 1.35v. With the BIOS voltages set to “auto” it reports 1.45v. During a PCMark run, HWMonitor reported a maximum vcore of 1.488v (although the number fluctuated a lot). Is this right? I had assumed the “auto” setting would target the default (conservative) voltages.
2. I have been having trouble achieving 3600MHz memory. When I enable XMP, the system simply fails to boot (locks before Windows). Through trial and error, I can get the system to boot at 3400MHz (manually configured), but it fails the PCMark run. 3200MHz appears stable, but a little disappointing considering the RAM XMP is rated at 3600MHz. Are the XMP values not guaranteed? I thought Ryzen 3000 would easily accept 3600MHz?
Any guidance would be greatly appreciated.
Cheers!
AMD Ryzen 9 3950X
Noctua NH-D15
Cheers!
