Caporegime
Hey will,
when you removed the stock cooler off your 4870 does the heat sinks for the ram and VRMs come off at the same time?
If they do can you reuse the thermal pads on them?
cheers
If you are referring to the stock HSF, then yea it does come off all at the same time, you can unscrew the cooletr and its split into separate parts, the fan comes off, the plastic covering, the heatsink base and the copper sinks come off separately too.
