Guitar Projects
18 Dec 2004
NE England
I'm not sure how interested in this any of you are going to be, but I'll post it here anyway.
Basically, the thread was inspired by SidewinderINC's guitar project, in which he was sanding it down then wanting to do a custom art design on it. Well I have two projects on the go which are simular.
The first (and current) is the Encore project. My first guitar was (obviously) a crappy Encore, and whilst it's not worth much and is a rubbish guitar, it still holds sentimental value in being my first. Also, it's cheap :p Which means I can break it and not worry about wasting £400!
So the deal with this guitar is to sand it down to the wood, dye it, then get all my friends to sign it, and laquer it up. It's more of a test to make sure I can do everything right before I start on a more expensive guitar.
The second project is the Maverick project. The Maverick X1 was actually my second guitar, but due to not knowing how to use a Flloyd Rose, I didn't use it for a LONG time. Having blocked the Flloyd Rose, I've been using the guitar for all my eMinor stuff, and I've realised how much of a lovely guitar it is (sans Flloyd Rose).
Anyway, due to the project, I thought I'd create a blog site for the project. Seeing as the Encore Project is the only active one, that's the only available page at the moment.
http://www.m0nkee.co.uk/blog
Any thoughts or comments would be more than welcome :)
Ta,
-RaZ
Good idea.
One thing though... you ever heard of Nitromorse (aka paintstripper?).
It will make your life a helluva lot easier with that paint removal!
I am going to do something with my Hamer, currently looking at turning it into a lego guitar or something with a ridiculous amount of LED's stuck on it - a la some other guys guitar on here.
Cool. :)
Yeah, I've been recommended it - but already got all the sanding stuff :] Plus something about it just sounds too easy... :p
-RaZ
when you've got a killer lump of solid mahogany at your disposal.. putting nitromorse on it is the worst idea in thr world!!!
ive totally sanded mine down now - put grain filler on and need to "rough it up" with some 400grit wet & dry paper ready for the sanding sealer.
