Guru advice welcome please
29 Jan 2006
Just bought a new setup and self built for the first time. Consists of:
Asus 8NV SLI Premium M/board
Athlon 3700 san diego chip
A Sapphire GTO2 card that I've opened up to the 16 pipes
2*512 Corsair 3200c2pt ram
250 seagate sata hd
nec dvd re
lite on dvd
sony floppy
astec sonata 2 case and psu
I've been toying with o/clocking and want to know if anyone can give me some better ranges keeping standard stock cooling.
The Bios I've set as
HT Freq - 4*
Dram Memclock - 400Mhz
Cas latencyTCL - 2.5
Min Ras active time TRAS - 6T
Ras to Cas Delay - 3T
Row precharge time TRP - 3T
memory timing - 2T
CPU freq - 240
PCI express clock - 100Mhz
DDR Voltage 2.75v
Chipset Voltage - 1.6v
HT Voltage - 1.25v
CPU Multiplier - *11
CPU Voltage 1.45v
then with Trixx I've set the mem clock to 540 and the VPU clock to 428.63.
I'm a rank beginner and if I've made errors please let me know. Also if anyone has some better settings I would really appreciate it.
By the way the 3D marks 2001se - 26443
3D Marks05 - 5631
regards
Stuart
Asus 8NV SLI Premium M/board > > Asus A8N-SLi Premium M/board
Dram Memclock - 333Mhz
Cas latencyTCL - 2
memory timing - 1T
CPU freq - 250
Chipset Voltage - 1.5v
HT Voltage - 1.20v
CPU Voltage 1.45v > > 1.5v?
thanks
thanks I gave this a try.
3Dmarks2001se - 26864
3Dmarks2003 - 11995
3Dmarks2005 - 5647
is this probably the upper end of this system without cooling mods etc?
regards
Stuart
