My car does it every time I fill up.
Nah it wasn't air going in, as soon as I twisted the cap it started releasing air, before I even touched the fuel pump. The fuel tank wasn't completely empty, it was at the last bar, so there was a bit left. I guess it could have been the heat as it was really hot that day.
Keep an eye on this. If there is a problem with the venting system for the tank then it could lead to an excessive pressure build up. I had this on the Caterham after the last rebuild; managed to get a kink in the vent hose so the tank couldn't breathe. The pressure was so high that the bottom of the tank bulged and split.
it makes no sense for air to be sucked in, but if he has his hand close by he very likely could have felt the gas flow past his hand
why wouldn't it? If a volume of fuel in a sealed container is removed, and no air has replaced it, what would happen to the pressure of the tank?
