WJA96 said:Amber for quiet cooling. The original ones had Ambers as standard, the new ones have cheaper, slightly noisier fans.
Just letting you know the black fan I got with my sidepanel is much quieter then the amber, gives decent airflow and spins at only 1200rpm. The amber spins at 1400rpm. What is weird is the Akasa Fan controller Pro gives the correct rpms for the side fan and my ac freezer 7 pro but reads my front and rear ambers at the max rpm of 1400 although the speed adjusts just fine. Brought them back to the shop and exhanged for 2 new Ambers which I am about to try.
