Guys, what is the best hair products?
12 May 2005
Hey...
This is possibly the strangest thread I have started, but basically:
As a guy, I have noticed there are so many different hair gells and so on, and I am just wondering what is the best one that does no damage to your hair?
On top of that, what is the best shampoo? I was told by my hair dresser that head and shoulders is bad for your hair, so I stopped using that ;)
Any advice :D
10 Jan 2004
All over
Shampoo - I use head and shoulders.
Gel - The mighty head shrink:
Somehow I've posted that pic 3 times in as many weeks :confused:
18 Oct 2002
Nottingham
For styling i use "L'Oreal tecni.art fix max" its a salon professional product i believe and it is very good!
As for shampoo i use fructis just cos i like the smell!
26 Mar 2005
Depends on your hairstyle mate, you want a stong hold, natural look - have a play with a few different ones, you can get a good idea of what they'll be like by opening them in the shop usually
Sic
Sic
9 Nov 2004
SO16
that stuff does nothing good for your hair. yucky stuff.
i use:
Shampoo - Original Source Rose (Taming and Defining)
Conditioner - same as above
"Gel" - Tigi Texturising Pomade
FGS, imageshack is a pile of crap today
20 Oct 2002
Redken do a good range for men. You can get their products from various suppliers on the net. Personally I use their Go Clean shampoo and Finish Up conditioner. As for styling products I use Toni & Guy X-Wax and V05 Texturising Gum.
