- 15 Feb 2013
- Edinburgh
Hey all,
I only just found this section of the forum, and I've found doing logs of things really helps move forward with it.
I'm planning on documenting my exercises I do, changes to my routine over time, and any things I do to diet/improve this.
Hopefully people might offer advice, or take things I learn on board to help themselves
hopefully I'll keep these stats up to date, and add any significant stats.
Currently (Jan 7, 2016) I am :
25, 75 kg and run a 10km in 41:46
My Routine:
Mon: Hill Runs, comfortable for 1min, sprint for 20secs for 2km uphill
Gentle downhill
Back up the hill, same sprint/rest pattern.
Gentle downhill
Total:8.2km
Tue: Gym, focusing chest/back (I suppose)
Pull ups: 3 * 5 reps wide arms
Seated row machine(I don't know machine names): 3 * 20 reps (38kg) both arms
Seated row machine: 3 * 10 reps (19kg) right only
Seated row machine: 3 * 10 reps (19kg) left only
Pull down Machine: 3 * 10 (80% body weight) both arms
Pull down Machine: 3 * 10 (40% body weight) right only
Pull down Machine: 3 * 10 (40% body weight) left only
dumbbell good mornings: 3 * 20 reps 10kg(scared of hurting back so starting low)
Leg lifts(holding body with arms, lifting straight legs to 90 degrees): 25 reps
Walking plank(transitioning from on elbows to palms and back): 1 min
Leg lifts: 25 reps
Walking plank: 1 min
Leg lifts: 25 reps
Ab rollout: 3 * 20 reps (the goal, third set's a killer)
Flat freeweight press: 10 reps (20kg dumbbell in each hand)
Flat freeweight press: 10 reps (25kg dumbbell in each hand)
Flat freeweight press: 3 * 5 reps (30kg dumbbell in each hand)
Inclined Freeweight press: 10 reps (20kg dumbbell in each hand)
Inclined Freeweight press: 3 * 10 reps (15kg dumbbell in each hand)
Vertical Tri Dips: 3 * 5reps
Tri pulldown machine: 3 * 10reps at (insert weight)
Bicep curl machine: 3 * 10reps at 20kg
Wed: Football or 10km with hills (depending on other people making football)
Thur: Shoulders(I suppose)
Standing shoulder lift: 3 * 15reps with 10kg dumbbells
Sideways dumbbell lift: 3 * 15reps with 5kg dumbbells
Forward dumbbell lift: 3 * 15reps with 7.5kg dumbbells
Seated shoulder lift machine(wide arms): 3 * 10 reps at 20 Kg
Seated shoulder lift machine(close in arms): 3 * 10 reps at 20 Kg
Standing pull up machine: 3 * 10reps at 10kg
Friday: Legs
Run(5km treadmill): plan 8, 25min
Squats: one min continuous.
Lunge Squats: each leg one min continuous.
Weighted Squats: 30 holding 15kg.
Weighted Lunge Squats: 30 each leg holding 15kg.
Quad lift machine: 3 * 20reps at 10(machine setting)
Leg press machine: 3 * 15reps at 80kg
Sat: Long Run
Run: 10 miles, or more depending on time.
Sorry for any and all mistakes in terminology, I'll update anything people have a better name for
My Routine:
Gentle downhill
Gentle downhill
Total:8.2km
Leg lifts: 25 reps
Leg lifts: 25 reps
Friday: Legs
Sat: Long Run
