- 31 Oct 2005
- South-West
Hi there,
Was reading about SSD's last night and found some info regarding Hybrid-Hard Drives.
Why haven't these taken off better?
From what I could tell (& I could be verrry wrong) it's a HDD with something LIKE a small SSD or flash based drive added into it.
That would allow windows to boot off the mechanical HDD then load all the programs your going to use & main windows files (Windows Ready Drive) into the small SSD/flash based drive so the HDD can spin down (save power) and surely response times would be a lot quicker.
Perhaps I don't know enough on it but even if the read/write times wern't faster than a standard mechanical HDD the access time would be instant so the PC would 'feel more responsive' surely even if it would be slower reading and writing massive files to it... which you wouldn't do, you would spin up the mechanical HDD to read & write massive files...
Could a 3.5 7200RPM drive not be put into a 5.25 box that contains a flash based drive that is 'around' 8-16gb that is around the same speed as the HDD? Like I said surely if the response time is quicker along with access times and even if the read/write speeds take a hit it would be quicker.
This seems to make sense when you think of Ready Boost having the page file on a flash memory drive. Althought it doesn't speed up on the first load, after that it helps the PC (PC's with lower RAM benifiting more) feel like it is running quicker as the files are loaded off the Memory stick Page File instead of the HDD which would have to seek etc...
I guess if the above is too big then a 2.5 drive into a 3.5 box with the flash based drive. This idea in would work the best in laptops so eventually getting down to putting it inside a 2.5 drive.
Just looking for someone to say 'No, you have it all wrong' or 'Yes but it doesn't offer a decent speed/response time increase / Not fiancaily viable'
Sorry for going a rant but just wondering really...
Cheers, Doug.
Cheers, Doug.
