can i ask that i have 2 akasa vipers to fit in a push pull on my kuhler 620. it comes with green flouescent rubber plugs. do i need extra long screews to?
if i buy 50 would anyone be interested in some ?
these are the ones ill be getting 6-32 x 1 1/2 lg UNC Cap Screws (black finish)
ill order quite a few as it cuts down on postage.
http://www.phobya.com/eng/phobya.html
if you go to products > screws, they do 6-32x30 in packs of 4. they seem to be alright for my h60
Well hopefully in my next build Ill get to use the 900D, A single Push Setup would look silly in it.... I suppose ill learn I'm still a bit of a WC noobi guess it depends how thick your case/fans are, they're fine for my case and an AF120.
if 30mm isn't long enough they do 35/40mm too.
I've ordered some now,got 50 coming![]()
