- 23 Nov 2014
- The Cronx
Hi all
Just a bit of idle curiosity at the moment, but any input much appreciated especially from experience.
2 of my systems sit next to eachother in the mancave. Red and Blue. The are both packed in to original H440 cases, purchased when they came out 2/3 years ago. Neither has perfect cooling. Red gets warm and Blue has a 4790K which obviously has heatsink problems (think H100i reported temp 38c package temp 60-70c running at 4.4 - delid candidate I think). Red has a 6850K on an H100i (intake top) and 2 Maxwell Titan Xs on EVGA coolers. Although liveable with summer hopefully coming, ideally I'd like to rehouse both sticking with the Red and Blue themes in matching cases, just because I'm like that.
TL;DR
Spec me a case available in Red and in Blue, with better airflow than an H440 series 1 with enough space for 1 240 rad and 2 120 rads (a Vega or two is destined for Blue and i'll guess they will be AIO). Bigger is fine, ideally under 200 each.
All the InWins etc "appear" to have the same restricted airflow.
Thanks in advance
TL;DR
Thanks in advance
