I'm actually really surprised how badly this is performing.
it made no difference when I had my cpu overclocked to 3.8GHz and has only gone down to 36degrees because I've switched the fans the way that is said and the window is open.
I used to get these temps before. I don't know if there's a requirement it the bios to set the 3pins to 100%, I've looked and played with them and again no difference.
my last cooler was the coolermaster v8 with varible speed so I'd take the guess that the pump should by default be on full. My case fan is the lower of the antec 1200 and that's again on full, the included corsair fan is plugged into cha_fan3 which didn't have any bios options, the ones which did where the opt_fan but again if I played I could only get 90% tops so again I'd have to believe they were full at default.
My motherboard is the crosshair III formula
watercooling kits are normally around £200. For the size of the H50 compared to an Air cooler it was worth it for me, but I wasnt expecting it to out perform something like a V8. Got a phenom 955 C2 @3.8Ghz atm with overclocked HT/NB Idle @41c and loads at 58c, so 36c seems pretty good?
so its no wonder why my overall cpu temp isn't too great. I blame the two Nvida 8800GT's i got running they run at like 70c
